MC 165 HP L6 timing plate illegible....
ParallaxBill
...can anyone tell me which point on the plate is 6' BTDC, or do you have a photo of the plate. Mine is too corroded to read the marks and I cannot remember how it was on my 78 Chevy PU that had a 250 L6 in it.
Need to check my timing properly.
Thanks,
Bill
BTW, I ran the boat for the first time today and it ran fine but was short on rpm's (3,500 @ WOT). Probably from the load of 4 adults and a recent change in prop pitch from the previous owner. He noticed the change about the time of the prop swap. I think I will need to swap a shorter pitch in to get me up to proper rpm's.
ziggy
Re: MC 165 HP L6 timing plate illegible....
this is off my 72 il6.....
ParallaxBill
Thanks ziggy!
Thanks ziggy!
That helps a lot even as corroded as your plate is.;)
Mine only shows the notches and points. I'll try to locate a new one to be sure in the future but it looks like 6' BTDC is the second full notch from the top of the plate.
Thanks again!:)
ziggy
i agree, the white hash mark is where i thought 6 btdc is. assuming, 8 after is the last hash mark, ea. hash mark being worth 2*.......
the sencond notch from the btdc side would be 6 btdc, if you look close ya can see an 8. on the btdc side.......
Silvertip
Look at the tab more carefully. Each point of the tab is 4 degrees apart (before and after 0 degrees). 6 degrees is the notch between the second and third point from the left. The markings are even readable.
Don S
See if this will help clear up the confusion.
ParallaxBill
No confusion...
No confusion...
...just lot's of good help. The notch I mentioned is the correct one according to all the input & my own figuring.
Great forum.
Thanks guys.:)
