mc1 lower bearing carrier removal? how hot?
big ken
need some help. i drilled and fractured old cover nut to get out, also removed keyed washer. made a puller to get out old bearing carrier. i need to heat, what would be the proper heating procedure? do i just heat around threaded area or the whole lower area? tourch or heat gun? thanks ken
Haut Medoc
Re: mc1 lower bearing carrier removal?
Spray some Kroil or PB blaster into the anchor points....
You can get it moving by placing two 3/4" pieces of wood between the prop & housing & tightening the prop nut, once youget it moving use your puller.....
If I were to heat it, I would use a torch....
Mapp gas works well.....;)
big ken
thanks. i like the prop and wood idea.
big ken
Re: mc1 lower bearing carrier removal? how hot?
still trying to get bearing carrier out. how hot do i get this thing?
Don S
If it's been in salt water year after year for many years and there is a lot of corrosion (and since you drlled the carrier nut out I would expect it is) you need BIG HEAT REAL FAST.
The big part is a real torch, then you have to heat the areas the carrier is still touching, very quickly so the housing expands a little and the carrier stays a little cooler.
But, you also have to not melt the alum. Since I have never used a temp gun to see what that number is, I can't really tell you how to judge. But you can not do it with a propane torch or a heat gun. Just not enough heat quick enough. You also have to have the puller in place and pressure on it when you start heating.
big ken
thanks don, i have a real tourch with the big ole rose bud tip for straighting frames. i can get a temp gun[what # should i look for?] also other than the edge where the carrier nut was, does it touch in the rear as well? thanks ken
Ayuh,....
I don't know about taking apart corroded cases,... I'd have Scrapped it by now...
But,...
Aluminum in general,.... 1200? is Too Hot....
JustJason
i can tell you because i've priced it out. Even if you keep your gears, if you need to reseal an alpha lower, AND if your replacing all the bearings, and if your paying somebody to do it...... it's more cost effective to get an SEI drive.
big ken
just got off ebay with guy. getting a complete se106 alpha for 1195.00 mating kit 50.00, 100.00 shipping. he will bolt them together add synthetic lube for no charge total 1345.00 and has 3yr warranty. what do you think? any better deals out there? ken
Don S
How about iboats, you know, the place where you learn about all the good stuff.
tboss
Ken let me give you a little tip , if you decide to rebuild you old unit - when you get to the part where you reinstall the carrier bearing before you try to install it take a rule or tape measure and measure the dia fo the opening to the housing then once you establish the measurement turn the tape measure 90 degree to he first measurement ansd see if there is any diff , it usually is egg shaped even thou its very small and im taliking in the thousands here .once you have established the widest piont in the dia of the opening take a largr C clamp and place it across the opening at the widest point tighten it a little bit usuall just enought to hold itself on the case now try to place the carrier bearing in and it will be a lot eaiser going in and it will make the tighten of the collar nut a whole lot easier. If its still tight turn the clamp a little more. but be careful and dont tighten it to much or you will warp the case the other way I did mine and this made it a lot easier. Good luck tboss
Don S
Use a tape measure to measure thousands of an inch of something being out of round?????
JustJason
Come on Don..... you MUST be able to measure down to at least 5 TEN thousandths with your bare eyes by now :)
tboss
You two guys cant see 64 thou. of an inch maby its time for an eye exam Im 67 yrs old and I have no trouble see that. But maby being a machinest for 45 years has something to do with it. If you can see a human hair then you can see 3 thous. for that the average with of one. IMHO
Haut Medoc
Micrometer eye......:D
Don S
Sorry, I just can't measure thousands of an inch with a tape measure, and that is what tboss suggested you use.
Below is his exact words, nothing about 64 thou there.
