1977 SILVERLINE
Thread starter- Joined
- Jul 11, 2011
- 113
I tried to remove the lower prop seals in my mc1 drive and am having no luck removing them. The problem is there is just no room to work with. I tried to drill a hole in the seal to allow me to use a screw to remove them but there is not enough room to drill. So I proceded to plan B, trying to remove the carrier that the seal is held in. I was able to remove the ring that holds the bearing carrier in place but I am unable to get the bearing carrier out of the lower housing. Any tips and tricks for removing the carrier. It looks to be aluminum and I am afraid if I use a gear puller I may break the carrier. If I could get the carrier out replacing the seals would be way easier. Thanks.
