Mc1 lower prop seals
1977 SILVERLINE
I pulled the seal retainer to install prop seals and now gear oil runs out of the prop. Do I need to add sealant where the retainer touches the gear housing? Thanks. 1977 470
kenny nunez
Did you clean the surface where the large “O” ring seals to the case and used a new one ?
Bt Doctur
Did you mean this
1977 SILVERLINE
So there is no need for sealant. The oring should keep the gear oil from running out.
Bt Doctur
only when #28 is tightened down compressing and expanding the O ring #17
kenny nunez
You really should use sealant on the outer of seals and “O” rings. The factory does it.
1977 SILVERLINE
I did not put sealant on the oring but I did on both surfaces that touch the gear case housing. Gear oil ran out really fast the first time that’s why I took it apart again and decided to apply sealant. Maybe i did not tighten the nut enough to compress the oring.
