mrsaundep
Thread starter- Joined
- Jun 9, 2009
- 55
MCM 140, Serial number, 5568367, with Delco Distributor
I rebuilt the engine last year after a core plug popped out. This included work on the ignition system such as new distributor cap, all leads, points & cond, rotor, plugs, and a full tune up as per manual #3 including setting the dwell and timing correctly. Since then she has been running great. Last time out she was good for an hour at about 2500rpm, then the revs started to hunt, up/down~2-300rpm for a few minutes, then she stalled. Would restart but would only run erratic and would stall at less than 1000rpm.
Have checked and renewed fuel filter/water seperator as there was some dirt in there. Also checked fine filter in the lift pump and the mesh at the carb inlet both clean.
Checked Cap, leads, plugs, points etc, all look good.
Re-checked points gap and then tried to check the dwell, but I cannot get it steady and the best I can get is it wandering between 30-34 deg. Same reading when cranking on the starter and when running and (trying to) hold revs steady ~1750rpm. Can't really check the timing as the revs hunt too much, have tried moving the distributor (advancing and retarding) from it's existing position and it does not improve, so I need to fix the problem before adjusitng timing.
I am presuming that this indicates a problem in the distributor (springs, weights?), and my next step would be to dismantle and inspect it. Anybody disagree and is there something else I have missed before I do that?
Many thanks, Paul
Many thanks, Paul
