natemoore
Master Chief Petty Officer
Thread starter- Joined
- Jun 13, 2009
- 844
MCM 165, 1987 engine
witnessing white smoke (or steam) upon warm engine restart
losing coolant somewhere
getting whiffs of coolant here and there
suspect that coolant is being burned up inside cylinders
otherwise engine runs okay
Leak down test results:
test 1 test 2
cyl 1: 35% 38%
cyl 2: 40% 41%
cyl 3: 43% 54%
cyl 4: 34% 40%
I heard air coming from valve cover, carb, and exhaust on all these. None were very loud.
Dry/wet compression test results:
Dry Wet
cyl 1: 180 180
cyl 2: 162 177
cyl 3: 155 162
cyl 4: 142 165
Keep in mind that I had a hard time getting a good seal on cyl 4 because of corrosion, so 4 may be better than what it shows.
What do you guys think? Can I continue to use this boat until a winter rebuild or do I need to pull the engine and rebuild it now. My wife is a teacher and is off until mid-August, so she'd rather me wait if I can.
test 1 test 2
cyl 1: 35% 38%
cyl 2: 40% 41%
cyl 3: 43% 54%
cyl 4: 34% 40%
Dry Wet
cyl 1: 180 180
cyl 2: 162 177
cyl 3: 155 162
cyl 4: 142 165
