charlescox
- Joined
- Jun 27, 2005
- 3
hi guys,<br />i have a 1982 470 that has had this problem ever since i owned it. It cranks and runs fine. This year the temp has been about 185 which seems a little high. When you run around a little while and then shut off the engine it only turns maybee a half of a turn or less. it sounds as though the batteries are dead. I have replaced the cables, had starter worked on , new brushes and bushings. still same problem. Last year it would help if we idled it down for a while before turnning off. My questions is is this still likely a starter problem , could it be getting too hot, or a timming issue. thanks
