rjrobin2002
Thread starter- Joined
- Feb 27, 2010
- 89
I built a 18' aluminum boat and built my transom angle to 15 degrees I thought. When I took it for its first test drive, I did not have enough down trim to keep the boat from bouncing as if my transom angle was not even close to 15 degrees. I set my angle by putting my angle finder on the bottom of the boat and setting the boat bottom at 0 degree. I then put my angle finder on the transom and tack welded it when the transom read 15 degrees. What did I do wrong?
