k4ubr
Thread starter- Joined
- Apr 25, 2009
- 65
i have an 6.2 mpi (2005) dry joint exhaust,seawater cooled. The STBR MANIFOLD runs 100 degrees hotter than the port . it will over heat the motor after about 10mins, on the water. ran motor check all temps with heat gun , on run up the risers heat up together but the stbr. stays at 200. wile the port comes down to 115--- back at idle, it takes about 10min. to drop 20 degrees. i have replaced, the seawater pump (assy) and 3 t-stats, headgaskets-2, stbr. manifold-riser new from MERC. and all plugs rotor and cap.
it seems the water is not leaving the manifold. the old manifold. did the same thing.. this is why i replaced the hole seawater pump. motor runs good. also i removed a broken flapper from the exhaust passage. for sure that was it,no dice.... all the same with no t-stat
