Mechanical fuel pump
Provo5
What is the difference between an auto mechanical fuel pump and a marine fuel pump?
Don S
Re: Mechanical fuel pump
An automotive fuel pump will leak gas into the bilge in great amounts if the diaphram gets a hole in it, in a boat, the gas goes to the carb.
In automotive, that leaking gas would be on the ground with fresh air around it, in your boat, if leaves all the gas and fumes and sparks from non marine parts a way of causing explosions and fires.
Provo5
Thanks Don, I think I will keep all my body parts intact and get the correct fuel pump.
