I have a mid 70's Merc 1400 140hp inline 6. It is a real pain in the butt to start cold. Carbs are clean and functioning, has plenty of spark and the choke seems to work good. Excellent compression in all cylinders, timing is set to spec. But for some reason the only way I can get this to start is if i use a spray bottle and squirt gas into the carbs while cranking the motor. Its almost as if the motor is not developing enough vacuum over the carb ventures to get the fuel into the motor. I have plenty of fuel pressure and gas leaks out the front of the carbs after intense cranking. Once i get the motor running and it gets hot it runs fine and starts on the first crank. Its just that first cold start i have to flood the case with a ridiculous amount of fuel to get it to fire???? Any Ideas?? Some one told me there are crank seals that go bad causing cold start issues???
