Title: 1989 MerCruiser Alpha One Gen 1 – Shift Cable Jams When Outdrive Is Fully Installed
Hi everyone,
I'm having a strange shifting issue with my 1989 MerCruiser Alpha One Gen 1 outdrive.
The lower shift cable is disconnected from the engine shift linkage, and I'm operating it manually by hand.
When the outdrive is partially inserted into the bell housing, I can shift between Forward, Neutral, and Reverse without any problems.
However, once I push the outdrive fully into the bell housing, the lower shift cable jams. I can't shift back into Neutral or Reverse, even before tightening the mounting nuts.
I also found a lot of water inside the shift cable slide cavity. The brass shift cable fitting is seized, and the hex head is now rounded off, so I can't remove it to replace the cable.
Has anyone experienced these problems? Could water intrusion or a damaged shift cable cause this? What's the safest way to remove the seized brass fitting without damaging the bell housing?
Any advice would be greatly appreciated. Thanks!
Hi everyone,
