Henchman 28
Thread starter- Joined
- Jul 5, 2008
- 2
Hello, I need some help.
I have been reading through the forums and trying to find as many answers as possible but I still have some questions.
Let me start from the beginning. I bought a 14 footer with a mercury 650E 1962. This boat was completely rebuilt by the previous owner. The motor was completely rebuilt with new fuel lines wiring and so on.
On to what happened, I took the boat out on the lake and it started up just fine and ran great all the way across the lake at full throttle. I turned off the motor and ate some lunch. I tried to restart the motor, the starter engaged, but the motor would not fire up. The wind kicked up and began to blow the boat toward the rocks and I franticly tried and tried to start the motor but ended up draining the battery. I had to jump in to keep my boat from smashing on the rocks. (ouch!) Long story short I got towed back in and took my boat home.
I recharged the battery and tried to start the motor, but only the solenoid would engage. As I was checking the connections my hand brushed up against the rectifier and I got burned.
So I figured my rectifier was fried and read through the forums and found a thread about rectifiers. I found this thread. http://forums.iboats.com/showthread.php?t=252433
Yachtzee posted a response to the topic about how he replaced his rectifier with a bridge rectifier 25 amp 50 PIV from radio shack and it worked fine. So I got the same one and hooked it up. (+ to +, ~ to ~ and - to -.) When I connected the battery, poof, the rectifier turned into charcoal.
Other than the rectifier, none of the wires or connections in the engine where burnt.
My questions are these.
Why would a new rectifier go up in a cloud of smoke?
Did I fry my electrical system?
Did I fry my started?
Did I fry my stator?
Where should I start to get my boat up and running?
P.s. The boat shops around where I live charge $95 an hour and it may take 3 to 4 hours to find out what is wrong with the motor before they can begin to fix it. $95 an hour! OMG!
Sorry if my post is too long.
Thanks
Thanks
