Re: mer model 110 drops a cylinder
Sounds like and electrical problem. What is the serial number of your motor? If you have a points and magneto system, it is most likely either points, condenser, or coil. If you can duplicate the problem, and determine which cylinder is not firing (perhaps by shutting it off immediately when it is doing this and then inspecting the plugs) you can swap components from one cylinder to the other one at a time and see when the problem migrates to the other cylinder. This can save a bunch of money just replacing parts at random.
Of course, before you do anything else, clean and gap the points and put new plugs in. Note which old plug comes from which cylinder, they may tell you something useful.
