Bigbearslayer
- Joined
- Jul 17, 2011
- 7
Ok let first start off by saying that this boat belongs to my buddy but we have yet to take it out because of runablilty issues. He completely tore down and rebuilt all the carbs and fuel lines, it is all brand new now. He brought the boat over to my house and we messed around with it a little more. We got it to fire up and it was idling and running great. Then my buddy shifted it into drive and all was well, he then shifted to reverse and it shut down. We put the motor back into neutral and started the engine again and it was running good until he put it in reverse and it instantly shut down. Basically we might have a two part problem here because I think there might be an issue with reverse but the main issue right now is that there is no longer any spark.
So far I have pulled a plug and used it to check for spark on all of the spark plug wires while the engine is being cranked and there wasn't any spark on any cylinder.
Next I pulled the distributor apart and check the points for cleanliness and proper gap, all was well in that department. While I had the distributor apart I checked the condensers by taking a resistance reading from the lead of the condenser to the body of the condensor but the readings went from OL to a range of numbers on both condensers which leads me to believe that they are at fault. I understand this could be the result of the no spark condition but the next thing I checked makes me wonder if it might be something else and the weak condensers are just amplifying this problem.
While the engine is cranking I tested to see if there was any voltage going to the coils and there was nothing on either coil, is this normal.
Basically I am just looking for a little advice on where I should have voltage in regards to the ignition system and how much and also some proper techniques for testing the coils, condensers, points, and anything else that I may have overlooked.
Thanks in advance for any input.
~Eric
~Eric
