merc 110 9.8 where is water discharge
don A
where is the water discharge [pee stream] or is it from the upper exhaust ports?
Laddies
Banned
Re: merc 110 9.8 where is water discharge
That depends on the year some with hoses discharge at the portside at the rear of the cowl, some early models discharge on the starboard side between the nuts that hold the powerhead to the mid section but 90% of the cooling water goes down insside of the exhaust tube.
don A
OK,thanks again , hoping to get it going soon and wanted to know where to watch for discharge.
EJ3
Don,
I have the same motor, mine is from the late 70's. Unfortunatly I am having a hard time remembering exactly what year, but I want to say 1978.
But, there is a tell tale on mine under the powerhead, or cowl I think its called. I am new to the boating thing and not up to date on all the cool lingo!!
don A
this is a 1967 motor,couldnt find a hose for tell tale discharge so i guessed it was through exhaust. i will see when i get finished with carb.just did not want to start with no cooling. thanks for the replies.
Harker
My 67 has a small hole next to the "flush" screw. It plugs pretty easily so I keep a wire handy to rod it out.
don A
Thanks harper, i found it! flushed out from flush hole.
Harker
Your welcome. Do you have the flushing attachment?
don A
no flushing attachment,water hose with sprayer adapter. dont know what the attachment is
flabum
Mine came out between the nuts.....just look for a pee hole. Use compressed air to blow thru to clear any debris.
