merc 1100s on 15 trihull
CaptainD101
Hey guys I just finished my 15ft riviera with new reinforced transom, all new gel coat.. transom is solid as a rock. I was looking at a 98 force 90 hp but is looking ruff outside and will need paint and hasnt been run in years. Then theres a motor that just showed up on craigs and is pristine and runs good. its the 1967 1100s and damn this thing is sweet, is there anything I need to know about these motors? Also I have a few questions myself?
how much does this motor weigh?
- is it in comparison with the 90hp
will this fit 20in transom?
can i find parts for this motor?
how much gas will this suck?
doesnt have trim, whats my options, how much?
i did a little research myself and really like the reviews of the tower or power. Im mechanically inclined an do most of my work. I need something really nice and turn key though for this project.. The guy is old and said this motor cranks right away. I know this is overpowered for my boat but plan to put on another boat later, dont plan to go crazy speeds with it on this boat.
CaptainD101
Re: merc 1100s on 15 trihull
i didnt leave the model its the 1100ssEL, so its the longer shaft of the two models. will this work on 20 in. transom
outlawfox13
EL designates it as a 25" transom as far as i know. If all else you can have the owner measure it from inside the transom clamp to the top of the cavitation plate.
mr 88
They weigh around 250.
The 1100 is around 95hp vs[ the different way they them today] 90hp.The 1100 is a smoother higher reving motor and is in a different class than the force.
Gas consumption ,3 mpg at 3/4-wot 4-5+ at cruise.
The latter models had trim pumps that go where your shocks are and will fit your engine.Ebay Craigs and Mercury dedicated sites should get you a setup for 2-300.
Parts are readily available net and word of mouth.
The wiring is prone to rot out and new wire can be spliced in or you can buy a new harness if shot.There should be a twist wire with a lead seal on it located on the side of the block, if there then the engine has not been apart.The timing should be[ if it has not already been done] retarded a couple degrees because of the crappy gas today vs 67..I have a 66 1100 that sat for 35 years in a dry part of the country, can you say mint? Anyway running it on a 66 15' 400lb tunnel with no issues. So as long as your within hp rating or have beefed up the transom with knee braces, I highly recommend it after a compression or boat ride test.
