so, I had took my boat to a 2nd mariina to check compression, First marina said not good and not worth repairing. 2nd did check and said compression is ok, and sound ok when running in tank.
They sid the middle carb was leaking and needed to be fixed befor he takes it out to test it ( it has a rattle when under load). now he said that the issue is a piston rod bearing is gone, and that is what the noise is. either repair motor or get new one.
I assume a re-build of the head is a big thing, but what would the cost be compaired to a new(er) motor?
So far it appears a half decent motor is around 3k.
its a '87 inline-6, perhaps not worth it.
