metalvolks
- Joined
- May 8, 2007
- 19
Hi,
I have an 82 Merc 115 6 cylinder. It has an original 230 hours on the motor. I believe that the water pump is original (don't know for sure).
When we flush the motor, it has a steady stream of water coming out of the pee hole. Also, when we are above 1500 RPM's or so in drive, it pees nicely. However, I've noticed that if I just put it in gear and putz around, the "stream" of water will sometimes stream and then sometimes "sputter." annndd... sometimes it stops for a second or two then comes streaming out.
I have been told that motors should have a steady stream of water coming out at all times (of course, the pressure would be different given different RPMS).
I just don't understand why at neutral (while we are flushing it) it works great, but when it goes into gear in the water it will sputter. (is it because of the vacuum the prop causes at certain speeds?)
*When I had the motor in the shop recently for a tune-up, the mechanic said that he didn't notice any problems.*
Do I need to replace the water pump? Also, being a car guy, I am curious about why some people opt to replace the water pump in their boats every 2 years or so. Shouldn't water pumps in boats and in cars be under the same stress? If that's true, then if a car water pump lasts for 100,000+ miles, I would imagine a boat pump working for a good number of years (500+ hours?).
Anyway, just curious
Paul
Paul
