Merc.115 sticky soleniod
skyblue729
Mercury 115 1992 soleniod sticks when it sits for awhile. Also, once engaged, the first couple revolutions, its slow like a very cold engine, than it spins freely.
Tryed to remove starter but two of the bolts are so tight the heads are starting to round. Any suggestions?
Chris1956
Honorary Supreme Mariner
Re: Merc.115 sticky soleniod
Sky, Are you talking about the starter solenoid, or the choke solenoid? The cure for a sticky solenoid (of either type) is to replace it. The starter solenoid is seperate from the starter, so tight starter bolts should have no effect.
BTW - the trick to take off tight bolts without rounding them is to use a good quality box wrench, and make sure it is seated properly on the bolt, before loosening it. Spray the bolt with some penetrating oil as well. You may also use a good quality six point socket to loosen tight bolts. Last resort is a pipe wrench.
