merc 115hp serial number please help
jason0316
I just recently got a new boat that needs work. Registration says motors a 1985 mercury 115hp. serial A127789 . I am in need of a carb rebuild kit and power trim motor but dont know which ones to get because all the online serial numbers for this yr motor are totally different than mine. So im lost at this point, anyone??
carholme
jason0316
Re: merc 115hp serial number please help
Not sure which on mine is. I posted pics so maybe you can tell by looking? If not what do i need to look at to tell which on I have? Also it has some kind of turbo jack plates? I know nothing about, do you? And turbo ss prop. Also about how much money the prop and jack plates worth? Trying to figure out how much to ask after i get this thing running a little better. Thanks
carholme
Jason;
I gave you both parts listings for you to look through to determine which one you have.
For example:
Does yours have this type of oil system?
http://www.crowleymarine.com/mercury-outboard/parts/278_30.cfm
Check the carbs
As it says 115 Power Trim on the front of the cowl, look and see what trim components you have.
As for the Turbo products, you should have p/ns which you can google.
Gerry
jason0316
oh ok. sorry . gotcha ya! lol. I checked some parts on listing out, I believe mine is just the merc 115 not the 1150.
