Fordiesel69
Thread starter- Joined
- Sep 18, 2009
- 1,146
You may have remembered my impeller topic, and with the #2 impeller now installed, it seems to be able to drive for 45 min without red lining (all the time I had to test). However the needle is right in between green and red like any minute it will overheat.
I am running 87 octane and the sticker says 93, and I can hear a very faint ping which is also makign me question is it really needing 93 or is it overheating?
The riser elbow is warm and you can keep you hand on it forever. The intake/exhaust manifold is also warm, but warm enough you can only hold your hand on it for about 15-20 sec. The block and head are too hot to hold onto.
There is a little molded rubber elbow going from the manifold to the t-stat housing that is always fairly cool like there is little flow.
How can I further diagnose if it is really overheating?
The t-stat in a pot of water will crack open at 140 degrees and be fully open at 160. Is this normal? It is a new one and it was stuck wide open when I picked up the boat which made the engine never heat up at all. I had to push it closed and now it seems to work fine.
