Hi all, I am having a few issues with my 1979 181 Merc 3.0 4 cylinder with the alpha outdrive. The boat had been stored for roughly eight years before I pulled it out and started to work on it, that was two years ago. I had to pull the engine, because I had a broken off starter bolt in the block. While I had the engine on the stand, I had the machine shop rework the head (valve job and hardened seats for unleaded fuel) and I replaced the oil pump. I also rebuilt the Rochester carb and installed a Petronox(sp) electronic in place of the points system in the distributer. I also replaced the rotor bug, Cap, plug wires, plugs, installed a water separator, and new fuel filter on top of fuel pump. I also have fresh fuel in now.
Here are the issues I am having. I have a knock or ticking sound coming from the valve cover, I believe. I have adjusted the valves at least 4 times, as it calls out in the Merc manual. The tick speed does increase while the motor rpm's increase, but doesn't seem to really get any louder. I have ran the boat on the water like this, without any problems...luckily. Could I have a collapsed lifter making that noise? I don't recall the valve train making this noise before disassembly.
The next issue I am having is with the timing and the carburetor. The carb is the Rochester carb with the two adjusting screws adjusted out 1 1/2 turns from seat as manual calls. I have the timing set at 6 degrees BTDC with a timing light and #1 spark plug at idle. Off of idle the motor wants to stumble before revving up. The motor seems to like life better the more I go BTDC. I believe I have the valves adjusted correctly, the timing set correctly, and the carb roughly dialed in. Could the advance springs in the distributor be wore out causing me a timing issue?
I probably only have 10 hours or so on the motor after all of this work. I hope I have given the pro's enough info about the problems I am having to help me in the right direction. Thanks in advance.
