merc 140 electronic ignition conversion.
jimmytee
The used boat I bought last year has a Merc 140 in it, with the electronic ignition conversion (replaces point and condenser). THe spark doesnt seem hot enough...its more of a yellow instead of blue. The coil also gets real hot; is this normal?
Don S
Re: merc 140 electronic ignition conversion.
Did you follow the instructions that came with the conversion exactly??????
jimmytee
Don, I didn't put it on, it came with the boat...I didn't even realize it until we started troubleshooting this spring. Should the coil get hot? And shouldn't it have a good blue spark? I did get it started tonight though....doesn't want to idle though...seems like its leaking air around the carb/manifold gasket. I bought a new one, but didn't quite look right, even though the correct p/n was on the package. It seems thicker than the old one also. I'll run over to the lake tomorrow and look at another new one just in case the first one was packaged wrong.
