Re: MERC 140 WATER IN #6 CYLINDER
I'm going to assume that your powerhead is mostly the same as my '69 100 HP 6 cylinder. Having just finished rebuilding my powerhead, I'm intimately familiar with the innards. There is no way possible for water to enter the crankcase from the lower bearing cap. For one thing, there isn't a water passage that flows through that area. And for another, if water DID get pushed up against it there are two rubber seals and a giant O-ring that it would have to get past. <br /><br />I think the gasket under the exhaust cover plate is the first place to look. The bolts on mine where well corroded and required a lot of penetrating oil and patience to get out. The new gaskets and new bolts for the cover will set you back about $50. If you also want to pull the powerhead and replace the gasket that goes between the powerhead and the leg (just for good measure), it will take about 4 more hours of work. I would replace the gaskets in the exhaust cover first and see if that clears up the problem.
