Merc 170 slow turnover
dpatzari
my 170 4cyl merc turns over real slow, regardless of battery charge. It also has been timed to factory specs. Any insight?
EddiePetty
Re: Merc 170 slow turnover
(1) Have battery load tested.
(2) Clean and tighten all electrical connections.
(3) Have starter load tested.
stonyloam
Those old 470 starters have a rather long armature shaft that can sometimes bend or break and then the windings will rub against the field coils and result in very slow turning. I replaced mine with a permanent magnet gear reduction starter that works much better and is about 1/3 smaller and a lot less expensive. Part # 2-2591-DR-2
