Gomer50
Thread starter- Joined
- Sep 5, 2009
- 507
I was given a 85hp motor that hasnt run in 5 or 6 years.She spins freely with no plugs in it,but when I put the compression tester on the number 1 plug she has a hard time cranking over.I have put oil in the cylinders spun them around with no spark plugs and she spins like crazy.I put the compression tester on the 2,3,4, it barley cranks over but I am showing between 150 and 140 psi. I spray oil in the number 1 cylinder and test she will show 150 then drop to 120 and sometimes will only show 100 psi.Battery is good maybe the starter isnt in the best of condition anymore.This test is done using jumper cables directly to the starter from the battery.I have also put seafoam in each cylinder and will let soak overnight see if this changes.My question is it possible the starter doesnt have enough umph to crank her over good,or might there be something else?
Thanks guy's......
Thanks guy's......
