merc 2+2 idle adjustment
mikey3091
Hello everyone! I recently cleaned the carbs on my 1989 merc 100 hp and am now having a problem setting the correct idle. What is the correct adjustment on the two idle screws for this motor? As I understand it, once I set the screws to a default, I then adjust to achieve the correct idle while under load. Is this correct?
Thanks in advance for the help!
