I have recently acquired a mid 1980s Blackmax 200HP motor. The motor runs but has a bad rod bearing. I have been planning on rebuilding the motor myself, but I talked to a mechanic who tells me that it is very likely that the crank is shot and will need to be replaced. Also, since this motor has chromed sleeves it will probably need to be re-chromed or replaced with a newer block.
So basically if all thats true, Im going from a nice affordable driveway rebuild to effectively buying a new (rebuilt) powerhead.
Id appreciate any comments on the assumption that the crank is bad and not repairable as well as it being a given that the chrome sleeves are toast.
Thanks for any input!
