JGra
Thread starter- Joined
- Apr 24, 2009
- 222
I am getting ready to order a lower seal kit for my merc 200. I have a leak at the prop seal due to some fishing line wrapped around the prop. From what I have been reading it takes a 2 seals for the shaft ( 1 faceing in and one faceing out) and a o-ring for the bearing carrier to seal this. I am going to order a lower kit as it is just a cheap to buy it this way instead of in pieces. My question is according one site I need 1 of 26-27163 & 1 of 26-26805 & 1 of 25-33465 (old merc numbers) for the seals. Both of the seals have been replaced by a single part number which is 18-2019 and the o-ring has been replaced by 18-7163. When I look up the contents of the lower seal kit which was 26-66303A1 (old merc number) and has been replaced by sierra 18-2627 it has all the parts I need but only list a qty of 1 of the 18-2019 seal. I have checked several sites but all have the same contents.
SIERRA 18-2627
( 2 ) 18-0595 Seal, replaces O.E.# 26-66303
( 2 ) 18-2004 Seal, Water Pump Base, replaces O.E.# 26-20070
( 1 ) 18-2006 Seal, Water Pump Base, replaces O.E.# 26-33467
( 1 ) 18-2019 Seal, replaces O.E.# 26-26805
( 1 ) Upper Face Plate to Water Pump Gasket, replaces O.E.# 24-39623
( 1 ) 18-2828 Lower Water Pump Base to Face Gasket, replaces O.E.# 27-39625
( 1 ) 18-2829 Water Pump Base to Gear Housing Gasket, replaces O.E.# 27-39626
( 1 ) 18-2945 Washer, replaces O.E.# 12-20260
( 1 ) 18-4261 Washer. replaces O.E.# 12-20262
( 1 ) 18-7120 O-Ring, replaces O.E.# 25-38933
( 1 ) 18-7163 O-Ring, replaces O.E.# 25-33465
( 1 ) 18-7164 O-Ring, replaces O.E.# 25-33466
( 2 ) 18-7180 O-Ring, replaces O.E.# 25-26802
My question is does it in fact take 2 seals? The parts breakdown does in fact show 2 seals on the drawing. Do I need to buy an extra one of the 18-2019 seals. Or I am missing something? Any help from the parts experts would be great. This is the last item to get done so the boat can be launched for the first time in 15 years. Thanks
SIERRA 18-2627
