OffShore200
Thread starter- Joined
- Dec 13, 2003
- 3
I have read through quite a few posts on Merc's overheating.... Not sure if any of them directly apply to my situation so let me lay it out... Hopefully someone can point me in the right direction.<br /><br />I recently aquired an overheating problem, only when I get it above 3000 rpm. After about 30-45 seconds above 3000 rpm the alarm sounds. I back off the throttle and the alarm goes off in 5 - 10 seconds. I have replaced the impeller, t-stats, poppet valve and diaphragm. Ofcourse, it is still overheating. <br /><br />I took manual readings of the temp via infrared thermometer and it shows that the starboard side is running 40 - 50 F hotter than the other side!?!?! <br /><br />I did see a post about a blown exhaust gasket, also another one about a mud dobbbers nest. What do you guys think?<br /><br />Thanks in advance!
