acadian2022
Thread starter- Joined
- Aug 14, 2022
- 98
Good morning all. I working on my Black Max 200 you can refer to engine detail Captain and I worked on this forum and now I'm timming this engine. I will upload sticker that is on the carb cover with specs and my home made diagram question to ensure I'm doing this right. I did disable the black box above the top carburator forgot its actual name
so I found true TDC from cylinder no 1 and now aim about to follow my diagram this wirh engine sparkplugs pulled out all grounded using stable DC volt charger to spin de starter at 300 RPM. my currently flywheel marked with vertical line and stamped 462 lines up with True TDC with cylinder no 1 and 11 dots beyond the 462 mark and from my research between 462 and the first punched dot = 30deg ATDC and the space between each dot = 2 deg. so the Idea is to use my caliper to measure 5 dots and mark the flywheel starting at 462 direction ATDC and then for the WOT BTDC 20 deg trottle wide open carb link was done add 10 dot please if possible look at my diagram and let me know if I going to avoid blowing up this sweet engine
I thank everyone in advance for your knowledge and help much appreciated
