MERC 25 powerhead swap
maineiac5586
I have a 2000 mercury 25 hp 2 STROKE WITH bad powerhead. I have a good powerhead from a 1982 MERCURY 25. Are they interchangeable? The 1982 powerhead looks slightly different on the front cover (maybe bolt holes for LINKAGES in different locations worse comes to worse I may need to swap the front cover from the 2000 to the 1982. Anybody have input into this?
maineiac5586
Also have access to a 1994 25 HP powerhead but I already own the 1982 powerhead. If I need to swap front covers what is used for the seal between front cover and cylinder block?
Faztbullet
It will fit with some mods due to cowling redesign...The 82 is a chrome bore model so inspect cylinders good as they scuff
maineiac5586
Lower COWLING or upper? Can you expand on what mods are needed? I think the front covers are different. If I have to swap the front covers what SEALS the cover to the cylinder block? By cover I mean the front section of the powerhead.
flyingscott
Are you getting the ignition with the 82 block? Are you getting the carb linkages with it? Those are different between those blocks. I would find another mercosil block like yours.
maineiac5586
Anyone know if a 1994 mercosil powerhead is interchangeable with my 2000 merc 25?
