- Joined
- Mar 8, 2009
- 44,758
Launched boat and wound up with 2 new issues. The first appears to be a slightly low Bat on the starboard motor. If keys are turned ON and each provides a single beep and it's started right away, I get 2 more beeps. It only happens with starboard and not the port. If I turn the key ON and wait for vessel view to power up it doesn't happen.
Disconnect shore power
Port Bat measures 13.2V
Starboard Bat measures 12.9V and so does the House
Bats are Group 31 Odyssey and are 1 year old, so still under warranty. Providing this in case it can also influence second problem
Problem 2
Boat came back from the dealer February this year and they said there was no issue with the port motor using more fuel than starboard. The video I provided showed about 0.2 Gph more. First run of the season and the motor kept getting worse, so much that at one time it was using 2.0 Gph more, then settled around 1.0 Gph more. At idle and running you could see and feel the motor vibrate.
Tech mate shows no codes and no history of issues since launch. This morning I had both running and switching between the 2 trying to see if there were any differences which there were none noted. This morning the port was not vibrating (missing). This afternoon I tried to connect my OTC fuel pressure gauge but while the fitting screwed on it would not stop leaking so I couldn't get a good reading. This is a fairly new OTC gauge set.
Wonder if this is a new Merc only fitting or other?
Problem 2
