Merc 3.0 Engine Block Drain Plugs Location?
Jacalore
Can anyone direct me to a photo or illustration where the two drain plugs are on an 1985 Merc 3.0 140? I can see the 'tee' on port side, lower back of the block, but can't seem to locate the manifold drain. Anyone? Thanks.
UNSUREBOATGUY
Re: Merc 3.0 Engine Block Drain Plugs Location?
Should be right above the "t" on the underside of the manifold.
fishrdan
Reach under the manifold and feel around, should be on the back half of the manifold, on the underside. There should also be a drain on the elbow/riser, port side. Then the block drain you found. The drains could have threaded plugs in them, instead of petcocks.
As has been said many times, the drain holes can get clogged with debris and it's best to probe around in the hole with a piece of stiff wire to get the gunk out, easy to do with plugs, can't do it with petcocks. I have petcocks on my engine and run them open/closed several times to clear the junk out, sometimes need to remove the petcock to get the big pieces of junk out.
JimS123
The petcocks and brass plugs on that vintage engine do not assure 100% draining of the water. You need to also pull the thermostat and upper hose and fill the block and manifold with anti-freeze.
Someone will soon post that I'm wrong. However, that's what the MCM140 3.0 liter Owner's manual specifies.
Jacalore
Thanks, I think I found them. BTW, my Merc manual says to just empty engine water thru plugs, raw water cooled, no need for antifreeze
Ayuh,.... That part is Right,... The Big hose should be pulled from the circulatin' water pump,...
That part, I ain't buyin',....
Jacalore
Big stuff? Is this common?
Jacalore
Okay, so both my drain plugs are petcocks. Does that mean I need to remove the entire plug, or can I poke thru the petcock to loosen any debris?
And, does it matter the order in which you drain - manifold, then block?
Ayuh,... There's 'bout a BaZillion types of petcocks, some straight through, many not,....
I, like ole DonS, prefer to toss those things, 'n get plain ole brass pipe plugs,...
1/4" pipe thread, takes a 7/16" wrench,...
When removed, ya got the maximum sized Hole to drain from, possible,....
Jacalore
Good idea! Thanks.
