merc 3.0 overheat @ idle and WOT
Munny
I have a merc 3.0 4cyl 140hp in my '87 four winns boat that is overheating at idle and WOT. It does not overheat at mid throttle but it does run hotter than norm. I understand the impeller may be the culprit for the idle overheating but could it also be the cause for the WOT overheat issue?
If I run at mid throttle the engine temp starts to drop. I had no over heating issues last year and the boat was properly winterized and stored indoors last winter.
I am thinking of getting a water pump rebuild kit, not just the impeller, and doing it myself. Any tips or words of advice would be appreciated.
Munny
Re: merc 3.0 overheat @ idle and WOT
Bump for help on water pump part #'s. Looking for a t-stat also. Any other parts I should consider?
Ayuh,... It's an Alpha 1,.... Click on the mercruiser parts button at the top of this page,...
And,....
Look it up Yourself.....
Munny
Thanks for the help with a bit of attitude. :D
I looked it up but wasn't sure which to get. I think I have it now....... A'yuh.
