All,
I posted this over the weekend and did not get any response, any help is greatly appreciated.
I am currently running the stock 1.45 jets in my 1989 3.0L merc 15P 4 blade prop, at high altitude, there is a little bogging...
I'd like to change the 1.45s out for the Merc recommended 1.40's for altitude between 5000'-9000', which will cover most of my needs, chatfield ~6000, Steamboat lake ~7000, green mountain res ~80000., Dillon 9000, etc etc
But what about when I go to Lake McConaughy which is I believe about 3250'
Will I need to change the jets back in order to keep from running too lean and burning a piston? or is that not enough altitude change create a problem?
I hope to put the 1.40's in leave them alone.
Any other altitude tweaks?
I hear advancing the timing also helps...
Not sure if it is relavant, but this week I am installing the following ignition components:
PerTronix Ignitor II
Flamethrower II Coil
So spark should be strong?
Thanks for the help
Thanks for the help
