Merc 3.8 question
racerman16
New to boats. I have a 84 merc 3.8. It seems like its definitely out of time. It will roll over and barely start. It acts like its retarded too much but then when i advance it, it will grunt and barely turn over when i do get it to fire it pops out of the exhuast and intake. I keep reading about it being an odd fire??? What does that mean? And something about an odd fire rotor? How do I check this? How do I properly install the distributor to get it in time? It's not like a car 350 where I bring number 1 to tdc then set it in and point it towards that cylinder is it? Thanks for any help.
Re: Merc 3.8 question
Mercruiser didn't make a 3.8, they did make a 3.7.
What's the serial # on the stamped tag on the block?
You time the engine exactly like you would a car.
edit...
I stand corrected, looks like they were the model 185
racerman16
Engine cover and out drive are stamped with the 3.8 liter badges. I have found info on merc 3.8's. They made them in 83 and 84 from what I have found. They are 229ci. But what I don't understand is the "odd" firing or fire order. I will get to the boat today and get serial numbers though. I tried to set it like a car but only half the cylinders seem to be firing at the right time.
muc
"Retired" Association of Marine Technicians...
This engine is called the MCM185R and it is 229ci
It is known as an “uneven firing engine” and used a special prestolite distributor.
The distributor should have 3 rounded lobes and 3 sharper lobes.
When installing the distributor it is important to have the points rubbing block on a rounded lobe for #1 cylinder.
Firing order is 1-6-5-4-3-2
Dwell 34 to 38 degrees
Timing 12 degrees BTDC
Advance curve starts at 1000rpm and goes to 20 degrees full advance @ 3500rpm
After getting the wires in the right place on the cap I suggest that you check spark advance in the water or on a dyno under load to see that you have 32 degrees of total advance @ 3500rpm
muc
P.S. this information comes from MerCruiser manual #7
And I would think about backing off the timing 2-4 degrees --- this engine was built back when we had better fuel.
Don S
Here is some information on the 185 from the #7 manual. Note the timing was changed to 8? in the spec page but still shows 12? in the ign. section.
attachment.php
attachment.php
attachment.php
racerman16
Ok. I will get out and check that. What about an uneven rotor? The guy I bought the boat from pit in new points, condenser and rotor. It looks like a regular car rotor. Is this ok or no? Thanks for all the help guys!!!!
Don S
Rotor has nothing to do with un-even firing. Did you actually read the text in the pictures I posted?
racerman16
Yes I actually read the text in the pics. I was just asking because it was something that I had read and wanted to double check because I do not know anything about these motors.
