timmeraw
Thread starter- Joined
- Jun 10, 2008
- 258
After taking the boat out for its maiden voyage yesterday I decided to check the gear lube(after it was like Molassis the first time I checked it and have replaced a couple of times since) ...and news is not good. It was pretty milky(more yellow than the chocolate milk color I have seen before) so now I suspect the seals are dried out after sitting so long.
I am supposed to go on vacation to Canada on Monday and am concerned that I will not be able to do the job of replacing the seals before then(not sure if I can even get the parts locally). Looking at the manual it looks like quite a complicated job to tear the lower unit apart.
Would I be crazy to use it daily a bit (changing the gear lube after) or am I risking trashing the lower unit by doing so? There was no real visible water running out btw.
Thanks,
Tim
Thanks,
Tim
