thundercat 9
Thread starter- Joined
- Oct 8, 2007
- 68
Re: merc 350 heads
I got this info from the Crane cams site, but that doesn't mean the info is correct:
Chevy Rockers: ?To Align, Or Not To!? - In 1988, Chevrolet changed their small block V-8 and V-6 rocker arm design to what is called a self-aligning type. The nose of the self-aligning stock rocker arm has a dimple on each side of the nose that contacts the valve stem area to hold the rocker arm over the valve stem. There is no guide plate or machined slot in the head to guide the pushrod. The pushrod only contacts the push rod seat of the rocker arm and the lifter. The pushrod should not touch any part of the cylinder head. Crane makes self-aligning rocker arms for both the 305/350 V-8 and the 4.3L V-6 engines, either 1.5 ratio 10751-1 or ?16 or the 1.6 ratio 10758-1 or ?16. These rocker arms cannot be used on engines that have pushrod guide plates or with heads that have pushrod aligning slots machined in the cylinder head. The rocker arms can only be guided by one method, not both.
