Leardriver
Thread starter- Joined
- Oct 7, 2008
- 382
I am trying to figure out a weird cooling problem. 2004 350 MPI, ow 011398, bravo three drive ow 222650. The boat found some sand in shallow water, and the smartcraft gauges showed raw water psi at .5 idle, 5.2 cruise rpm, which was previously 7 psi idle, 9.8 cruise.
So, I figured that it sucked up some sand, degrading the performance of the impeller.
But... the engine now registers temps of 135-140, down from 165 previously. I once again was trying to guess why it was running cooler. Chunk of impeller or a rock wedged in the thermostat, blocking it open? Yes, the cooling water pressure was less, but the engine ran cooler, not hotter.
I replaced the impeller. It was all there, and in pretty good shape, but the raw water pump is a drag to get out, and a new impeller is never the wrong thing to start with.
I replaced the thermostat and gaskets, even though the old one boil tested perfectly at 160 degrees.
The cooling system looked perfect, and I ran hose water through the hose to the outdrive pickup, and full water pressure came out. I was testing for an obstruction.
Now, the water psi on the gauge shows 0. I tried it on the hose, dragged it to the lake to drown it in water, and no reading at all. I shut it down after 10 seconds, but I fear that I have to take it all apart again, which is a pain in this heat.
Any ideas? Pressure indicating problem? Where is the pressure sensor located?
The raw water pump had plenty of resistance when I spun it by hand, just like a new impeller in the housing should be. The two raw water hoses went back on like they came off. I didn't get them mixed up. I took pics before and after.
Update-took it apart again. It's amazing how the first time takes 2 hours, and the second time took 17 minutes. The impeller and pump internal housing looks brand new, just like I left it. Some water in there. I flushed the red top hose from the raw water pump again. It is a gusher out the pickup on the outdrive. Great flow. I hooked the ears up to the outdrive, a gusher inside the boat now. I think the water intake path is unobstructed.
Why no psi reading from the inlet water pressure on the gauges?
