EDIT: So i figured out the switch and the cable are OK on my 1990 merc 4.3. I started looking into the wiring (thunderbolt IV) and the white/green wire is directly connected from the distributor to the ignition "box" mounted on the manifold. Its got a diode right next to the bullet connector. There is also a white/green wire coming out of the interrupt switch then goes into the harness under the manifold and i believe it just loops around back up to almost the same spot in the back of the manifold and it has a ring terminal on it that was taped up. If i probe the wire between the diode and the box and hook it up to the white/green connected to the interrupt switch it kills the motor when i activate the switch.
my question is how does the factory wire it up? Looks like wiring was never modified. did someone not wire it right from the factory? according to the diagrams the white/green wires should all be connected. do i connect the white/green to the negative of the coil and it just grounds out the coil to kill it momentarily?
