nazmen1
Thread starter- Joined
- Jan 23, 2009
- 39
My engine is a 1978 Merc 402.
The initial problem was the engine would not run. With the help of some people on the forum, Laddies, I narrowed the problem down to some very brittle wiring in the wiring harness and stator as well as a bad switch box.
I replaced all the brittle wiring, purchased and installed a new CDI switchbox. In the process of replacing the wiring on the stator I removed the flywheel to get as much of the brittle wire as possible The replacement wiring is making good contact. I marked the flywheel with the a marker for Top Dead Center, TDC, also using a screwdriver in the #1 cylinder to confirm.
In order to remove the flywheel I had to use a puller which required removing the bolts from the hub and a lot of effort since it has been on there for almost 30 years. I was careful as I could be not to rotate anything when it finally came apart.
Everything is back together and I have strong spark on both cylinders. I am preparing to fire it up with fuel.
I noticed tonight that the mark that I made with a black sharpie as TDC is aligned with the mark on the edge of the flywheel with 2 dots with the timing pointer. See the attached photo.
There is another line on the flywheel 5 gear teeth on the edge of the flywheel to the left in the photo, or clockwise.
Question: Are the 2 dots on the edge of the flywheel, TDC or is TDC the mark on the edge 5 gear teeth clockwise? Using a screwdriver in the #1 cylinder, there is enough play to believe it could be either one. If I did manage to rotate the flywheel from its original position what problems might I encounter.
Thank you.
Thank you.
