I have a 2003 Mercruiser 5.0 305hp V8. First time out for the season. I have a fully charged battery that I load tested, it's fine. Start engine it runs great for 3 - 4 minutes then stalls. Won't start again for a few minutes. Then it'll start, run for about 30 seconds then stall again and the cycle continues.
I replaced the plugs, engine oil and filter, fuel filter/water separator just to give it a good tune up. Symptoms continue.
It seems that something is failing once it warms up. Does anyone:
Thanks!
- Recognize this issue?
- Have any idea how to test the fuel pump assuming it's the cause
- know any voltages I can monitor to test anything such as the fuel pump or computer?
- Where to buy a fuel pump pressure testing device?
Thanks!
