Ayuh,... I use the whip of my compression tester to blow compressed air back into the cylinder,.....
Roll it up to Tdc, 'n Blow,....
You'll Hear where the airs comin' out,....
The carb, a bad intake valve,....
The exhaust, a bad exhaust valve,...
Through the oil fill, a holed piston,...
Has it been runnin' poorly at high load conditions,..??
A lean condition is probably the #1 cause of detonation,....
