Merc 5.7 engine rattling after sitting 1 month
JustJason
Re: Merc 5.7 engine rattling after sitting 1 month
but you need to get out of the habit of only checking the oil after it has been warmed up
Agreed. If the oil shows full on a warm engine that was just shut down you can very well be over full as the oil hasn't settled back into the pan yet.
littlebookworm
After reading through the post and responses, one thing seems to remain constant: the noise begins and ends at approximately 1900 RPM. Above it - noise; below it - normal. I've worked on more car engines than boat engines, but a GM small block is the same no matter where it is. I've had the experience of having a bad lifter or two on a small block which would "leak down" at higher rpm, opening the gap between lifter, valve, and push rod. When we worked on a car engine, we would use a modified valve cover to control oil splash and would run the engine with a squirt oil can handy to flood a questionable lifter. That's quite on job on the Mercruiser engine because the exhaust manifold has to come off to get the rocker cover off. A mechanic's stethoscope will help you isolate which side of the engine the noise is coming from so you'll, hopefully, have less to disassemble to check it out. Good luck and let us know what you find. Hy
