northernmerc
- Joined
- Apr 6, 2009
- 401
I have a 1978 Merc 50 hp, 4 cyl. It only runs on two cylinders. Compression is excellent and fuel system is fine.
Only the two bottom cylinders are firing (determined with timing light hooked up to the plug wires one at a time). I switched one of the coils from the lower cylinders to one of the top cylinders and determined that the coils are OK. I also switched the leads from the stators at the switch box and determined that the stators are OK. After switching the stator leads, the same two cylinders still did not fire.
As far as I know, that means that the switch box is bad. Am I missing any other possibilities?
I assume that the switch box is not serviceable and that the only option is to replace it. Or is it possible to fix a non-functioning switch box?
Thanks in advance for your advice. I don't want to buy unnecessary parts and would like to narrow this down as much as possible.
