merc 50 hp. 4 cyl.
jim372
I have a merc outboard s.n. 06486332 that turns over fine but no spark
like to know were the neutral sw. is located
is it on motor near linkage or on controls
GA_Boater
Re: merc 50 hp. 4 cyl.
The neutral switch is in the control. It has nothing to do with spark, it doesn't allow the starter solenoid to energize if the control is in gear.
jim372
thanks
that does away with one idea I had
I found broken wire from trigger coil
to switch box , wirring out of trigger
looked brittle
do you think trigger is bad
Laddies
Banned
Here's he test for the ign. from CDI those older enginers are having trouble with the wire insulation falling off but many people repair them.
GA_Boater
If you found one crumbling wire, check all the wires. Fix them and then follow the CDI test Laddies posted. Those harnesses start to fall apart after a while.
