Chinewalker
Thread starter- Joined
- Aug 19, 2001
- 8,902
I pulled a good one on this motor. Already too much time into it but in for a penny, in for a pound.<br /><br />Background - replaced the block as the first was scorched pretty badly. Never took exhaust cover off replacement block for fear of breaking some bolts. Assembled motor and fire it up. Ran on three cylinders, found water on the #2 plug. Ended up pulling the exhaust cover, breaking four bolts in the process, found a crack in the inner cover. Repaired bolts, replaced inner cover, motor runs much better.<br /><br />Now for my "good one". When I disassembled the motor, I took the flex plate and outer rim off the flywheel hub. Using a punch, I marked it as to where it was suppose to go when I reassembled it - or so I thought. I had marked the rope sheeve in the middle, which of course is seperate from the flex plate and the hub, so now the timing marks are out of whack, even after my best guess for realigning the flex plate to the hub.<br /><br />My question - I'm not far off, as the motor does run, but I think the timing is up too high - the motor falls flat and pings like crazy if I go anywhere above a fast idle in gear. Can anyone tell me where the crankshaft keyway ought to be in relation to the arrow cast into the top of the magneto pulley? OR, can anyone tell me where the #1 cylinder TDC should be in relation to the arrow on the pulley. I'm not going by the line marks on the pulley cap - just the marks on the pulley itself with that cap removed. The manual is useless because it goes by the marks on the flywheel - which of course are out of whack on this one, so I need to find some non-flywheel refereces to work with. Anyone got a "trick" for getting things lined up again?<br /><br />Doh!! Thanks!!<br />- Scott
