Re: Merc 500 Revival
Guessing the carbs need new gaskets (built in fuel pump). When I try to prime the bulb I notice that once the bowls fill, fuel leaks our the carbs and the bulb won't stay stiff. Easy fix.
Big problem now.. Engine runs fine at idle. I let it warm up. Make sure the choke is off. Put it in gear and... nothing. I barely go anywhere. The engine still runs but I have no power. I can put around at an idle pace with the throttle all of the way forward.
When I try to put it in reverse I get a grinding sound and no reverse. I immediately put it back in neutral to not grind anything up.
Ideas?
Ideas?
